Problem with 100ABUV6C0 firmware for NR7101
jeroen_s
When I try to upgrade over the management WiFi network I always get:
Image uploading failed. You may press 'Cancel' to upload another firmware image file, or press 'OK' to reboot to recover normal operation.
Edit: I should add that I'm currently at 100ABUV5C0
Over wifi network? What do you mean?
I mean I connect to the device via the management wifi network that the device provides.
Finally figured this out. The problem was Safari. Previous were fine...
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
