Disable SSID schedule via iOS App
hi, many consumer want there wifi disabled during the nighttime,
but sometimes they need the wifi, it would be good to disable the SSID schedule (08.00-22.00) and manualy set the wifi acctive.
There is a option to set the plan unscheduled but it jumps automatic back to the last schedule (i.e. 8.00-22-00) instead of deactivate it (Nebula iOS app V3.3.1)
In addition, the schedule configured in the Nebula web application is not visible in the iOS app and cannot be controlled
has anyone same problems or even a fix?
Hi Customer,
Related to the issue of option to set the plan unscheduled but it jumps automatic back to the last schedule, we meet the same symptom here, so we are going to checking the root cause. We’ll update you if anything is in new progress.
APP’s SSID >> Advanced Setting tab just shows the popular option that almost of users often use to let the APP’s page layout become simple and friendly. The schedule configured as “Custom schedule” or other advanced options/ functions, we recommend the user go to the Nebula website to do configuration.
Zyxel_Judy
Hi there,This issue will be fixed next version (APP 3.4.0) for iOS at October 31th, 2022.Please follow us to know more information about our product.Thank you for your patience!
Zyxel_Judy
- 220 Nebula Ideas
- 607 USG FLEX H Series
- 299 Service & License
- 482 News and Release
