Zyxel LTE 3301-M209 router does not work with a static vodafone ip address
if0else9
if0else9 Posts: 1 image  Freshman Member
The Zyxel LTE 3301-M209 router does not work with a static vodafone ip address. Root access via ssh is also missing to set this value. AT+CGDCONT=1,"IP","staticip"
  • tonygibbs16
    tonygibbs16 Posts: 979 image  Guru Member
    50 Answers 500 Comments Friend Collector Fifth Anniversary
    edited September 2022
    Hello @if0else9
    Looking at the user guide available at https://www.zyxel.com/global/en/support/download?model=lte3301-m209 then you are correct.
    There is no ability to put a static IP address into the Management WAN screen.
    I think that Mobile Network Operators (MNO) like Vodafone reserve the right to give out different IP addresses in different parts of their network.
            - so the device gets its IP address dynamically from the MNO.
                     - The MNO might give the same IMSI the same IP address all the time if they see it in the same cell...or they might not.
    Kind regards,
         Tony
