Recover Missing NAS Shared Folder (NAS changed its status to 'Lost')
Christos_Koziaris
Hi
On a NAS326, a Shared Folder disappeared and changed its status to 'Lost'.
As I cannot edit the entry of the Folder, how this can be recovered?
Do you have two volumes? If yes, are they both healthy?
I am having exactly the same problem and need help with this
I have the sam problem. After reset a can’t change the “Lost” status to “Normal”
Do you have some solution for it?
Thanks a lot!
I think a share is 'Lost' when the shares database says there should be a share, but the corresponding subdirectory on the data volume isn't there.
A subdirectory can disappear on a hard reset due to a filesystem corruption. In that case it might be in the lost+found directory, where the filesystem dumps all files which doesn't seem to have a parent directory.
Login over ssh, and execute
su cd /i-data/sysvol/lost+found ls
If ls shows anything, that could be your lost data.
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
