NAS 540 won't boot
BjoWis
BjoWis Posts: 33  Freshman Member
My NAS540 won't boot properly and I have hooked up the serial port and exported the bootlog. Can someone please help me fixing the problem?
Any help would be greatly appreciated, since I am quite new to this.
booting kernel of type uimage from /dev/nand0.kernel1.bb
Bad Header Checksum
 Failed.
booting kernel of type uimage from /dev/nand0.kernel2.bb
Bad Header Checksum
  • Mijzelf
    Mijzelf Posts: 2,931  Guru Member
    As that box is fairly old, I suppose you have upgraded the box at least once, I guess? That means both 'slots' with kernels are filled, and apparently both are damaged. Don't know what that means.
    You can try to tftp a kernel, boot that, and then upgrade the firmware, if the webinterface comes up. If the webinterface doesn't come up, you can use a 'flash stick'
    To tftp a kernel you need a tftp server. Google for that, to find one for your platform. It's a small piece of software.
    In this post you can find the command to pull the kernel from the server, and boot it. Elsewhere in that thread you can find a download link for that kernel.
    BTW, seeing your log, it seems to me barebox is trying to fetch a kernel by tftp:
    warning: No MAC address set. Using random address 3E:25:A4:02:6E:3F
    T T DHCP client bound to address 192.168.1.83
    T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T
    Those T's are typically timeout messages from a tftp client. So if your dhcp server supports tftp (for instance a router running OpenWrt), you can simply provide the kernel with the right name (which could be found in the tftp server log) and the NAS will automagically fetch a kernel when it can't find one in flash. Network boot!
  • BjoWis
    Hmm... I've now made some progress, kernel was fetched via tftp. But it runs into some problems when flashing.
    I used the kernel provided by you - renamed it to uImage.520.bin from uImage.520ABAG1C0.bin
    See attached log.
    [033mMount system partition...[0m
    crw-rw----    1 root     root       10,  58 Jul 12  2012 /dev/ubi_ctrl
    ubiattach: error!: cannot attach mtd7
               error 19 (No such device)
    mount: unknown filesystem type 'ubifs'
    NAND Flash Corrupt...
    the sys-root image /dev/mtdblock7 is currupt !!
    Open /dev/mtd2 void
    Open /dev/mtd2 void
    change boot image and reboot !!
  • Mijzelf
    Hmm, there is more wrong than 'just' the kernels in flash. The commandline should specify the flash partitions, which it doesn't. Yours is
    console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes  mac_addr=,,
    it should be
    console=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes  mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,2048 rootfstype=ubifs rw noinitrd mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved) usb3_internal_clk=yes
    (Both are single lines). Here you can find a serial bootlog of a healthy 540.
    The commandline is build by barebox using it's environment variables. So I *think* you've got a damaged environment. And possibly your kernels aren't damaged at all. Their addresses are also stored in that environment.
    In this thread repairing the environment is discussed. I remember there was also a thread in which tftp was used to transfer a binary dump of a healthy environment partition, and flash is using the bootloader. But I can't find that now. This forum is at the moment painfully slow for me.
  • BjoWis
    Hmm... now my barebox don't have any LAN?
    Unknown command 'export' - try 'help'
    Disabling eee function of phy 4 ...
    Disabling eee function of phy 6 ...
    Hit any key to stop autoboot:  1
    Bad Header Checksum
     Failed.
    Bad Header Checksum
    warning: No MAC address set. Using random address 6A:D6:AC:D9:E7:F7
    phy0: Autonegotiation timeout
    PHY auto-negotiation error
    I've tried the LAN cable on other devices and it's working properly. And the phy command within Barebox  is a bit confusing for a noob like me.
    Barebox-C2K >/ phy
    Usage:
     phy stat                       show all the phy status
     phy init phyno         init the PHYs. For WAN, the PHY no is 4
                                    for LAN, the PHY no to be 0 to set PHY0-3
     phy read phyno reg             read the PHY register
     phy write phyno reg data               write the PHY register
    Any idea?
  • Mijzelf
    Have you tried both ports? It is possible that a simple power recycle isn't enough to fully reset the phy. Unplug the powersupply for at least 10 seconds. If that doesn't work I don't know.
    When I remember well the heatsink of the SoC has to be removed to be able to connect the serial port. Did you feel if it's not getting too hot?
  • BjoWis
    Ok, it might have been some strange yesterday - because when I tried now it works again
    So I tried copy the uImage to a specific address, but that resulted in the following
    Barebox-C2K >/ eth0.ipaddr=192.168.1.191
    Barebox-C2K >/ eth0.serverip=192.168.1.20
    Barebox-C2K >/ tftp -f uImage.520.bin -a 30010000
    tftp: invalid option -- f
    tftp: invalid option -- a
    warning: No MAC address set. Using random address C6:DC:65:89:74:E4
    TFTP from server 192.168.1.20 ('uImage.520.bin' -> '30010000')
    Barebox-C2K >/ bootm 30010000
    ERROR: out of memory
    TFTP didn't like the options -f and -a
    And I ran out of memory, trying multiple random addresses (80010000, 70010000, 60010000, 50010000) all with the same result "out of memory"
  • Mijzelf
    faierbol found them to work, and where I pointed to.
  • BjoWis
    So @faierbol did you manage to repair environment and the faulty commandline? I have run into the same issue. Any help/guildline would be appreciated.
    Mine is
    While it should be
