NAS 540 won't boot
BjoWis
My NAS540 won't boot properly and I have hooked up the serial port and exported the bootlog. Can someone please help me fixing the problem?
Any help would be greatly appreciated, since I am quite new to this.
booting kernel of type uimage from /dev/nand0.kernel1.bb
Bad Header Checksum
Failed.
booting kernel of type uimage from /dev/nand0.kernel2.bb
Bad Header Checksum
Bad Header Checksum
Failed.
Bad Header Checksum
As that box is fairly old, I suppose you have upgraded the box at least once, I guess? That means both 'slots' with kernels are filled, and apparently both are damaged. Don't know what that means.You can try to tftp a kernel, boot that, and then upgrade the firmware, if the webinterface comes up. If the webinterface doesn't come up, you can use a 'flash stick'To tftp a kernel you need a tftp server. Google for that, to find one for your platform. It's a small piece of software.In this post you can find the command to pull the kernel from the server, and boot it. Elsewhere in that thread you can find a download link for that kernel.BTW, seeing your log, it seems to me barebox is trying to fetch a kernel by tftp:warning: No MAC address set. Using random address 3E:25:A4:02:6E:3F
T T DHCP client bound to address 192.168.1.83
T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T T TThose T's are typically timeout messages from a tftp client. So if your dhcp server supports tftp (for instance a router running OpenWrt), you can simply provide the kernel with the right name (which could be found in the tftp server log) and the NAS will automagically fetch a kernel when it can't find one in flash. Network boot!
Hmm... I've now made some progress, kernel was fetched via tftp. But it runs into some problems when flashing.
I used the kernel provided by you - renamed it to uImage.520.bin from uImage.520ABAG1C0.bin
See attached log.[033mMount system partition...[0mcrw-rw---- 1 root root 10, 58 Jul 12 2012 /dev/ubi_ctrlubiattach: error!: cannot attach mtd7error 19 (No such device)mount: unknown filesystem type 'ubifs'NAND Flash Corrupt...the sys-root image /dev/mtdblock7 is currupt !!Open /dev/mtd2 voidOpen /dev/mtd2 voidchange boot image and reboot !!0 -
Hmm, there is more wrong than 'just' the kernels in flash. The commandline should specify the flash partitions, which it doesn't. Yours isconsole=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,,it should beconsole=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,, ip=dhcp root=ubi0:rootfs ubi.mtd=2,2048 rootfstype=ubifs rw noinitrd mtdparts=spi0.0:256k(uloader)ro,512k(barebox)ro,256k(env);comcertonand:10M(config),10M(kernel1),110M(rootfs1),10M(kernel2),110M(rootfs2),-(reserved) usb3_internal_clk=yes(Both are single lines). Here you can find a serial bootlog of a healthy 540.The commandline is build by barebox using it's environment variables. So I *think* you've got a damaged environment. And possibly your kernels aren't damaged at all. Their addresses are also stored in that environment.In this thread repairing the environment is discussed. I remember there was also a thread in which tftp was used to transfer a binary dump of a healthy environment partition, and flash is using the bootloader. But I can't find that now. This forum is at the moment painfully slow for me.
Hmm... now my barebox don't have any LAN?Unknown command 'export' - try 'help'Disabling eee function of phy 4 ...Disabling eee function of phy 6 ...Hit any key to stop autoboot: 1booting kernel of type uimage from /dev/nand0.kernel1.bbBad Header ChecksumFailed.booting kernel of type uimage from /dev/nand0.kernel2.bbBad Header Checksumwarning: No MAC address set. Using random address 6A:D6:AC:D9:E7:F7phy0: Autonegotiation timeoutPHY auto-negotiation errorI've tried the LAN cable on other devices and it's working properly. And the phy command within Barebox is a bit confusing for a noob like me.Barebox-C2K >/ phy
Usage:
phy stat show all the phy status
phy init phyno init the PHYs. For WAN, the PHY no is 4
for LAN, the PHY no to be 0 to set PHY0-3
phy read phyno reg read the PHY register
phy write phyno reg data write the PHY registerAny idea?0 -
Have you tried both ports? It is possible that a simple power recycle isn't enough to fully reset the phy. Unplug the powersupply for at least 10 seconds. If that doesn't work I don't know.When I remember well the heatsink of the SoC has to be removed to be able to connect the serial port. Did you feel if it's not getting too hot?0
Ok, it might have been some strange yesterday - because when I tried now it works again
So I tried copy the uImage to a specific address, but that resulted in the followingBarebox-C2K >/ eth0.ipaddr=192.168.1.191
Barebox-C2K >/ eth0.serverip=192.168.1.20
Barebox-C2K >/ tftp -f uImage.520.bin -a 30010000
tftp: invalid option -- f
tftp: invalid option -- a
warning: No MAC address set. Using random address C6:DC:65:89:74:E4
TFTP from server 192.168.1.20 ('uImage.520.bin' -> '30010000')
Barebox-C2K >/ bootm 30010000
ERROR: out of memory
TFTP didn't like the options -f and -a
And I ran out of memory, trying multiple random addresses (80010000, 70010000, 60010000, 50010000) all with the same result "out of memory"0 -
faierbol found them to work, and where I pointed to.
So @faierbol did you manage to repair environment and the faulty commandline? I have run into the same issue. Any help/guildline would be appreciated.Mine isconsole=ttyS0,115200n8, init=/etc/preinit pcie_gen1_only=yes mac_addr=,,
While it should be
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
