LTE firmware for SBG3600
1246720
  • Zyxel_Cooldia
    Zyxel_Cooldia Posts: 1,520  Zyxel Employee
    Hi @hojdy,
    Because it get the incorrect value to display status bar in previous version, and we fixed it since AAZE.8.
  • Sakari
    Sakari Posts: 2  Freshman Member
    Does the SBG3600-N support Zyxel LTE modems? They are not listed in supported modems list.
  • Sakari
    What are the LTE settings for Elisa network in Finland?
  • Zyxel_Cooldia
    Hi @Sakari,
    The LTE configuration as below, APIN code is a key to a SIM card, If PIN code authentication is enabled on the inserted SIM card, enter the 4-digit PIN code provided by your ISP to unlock the SIM card. As for APN settings, select this option to get the APN automatically from the service provider.
  • turkawka
    turkawka Posts: 1  Freshman Member
    Can you please send the firmware for me as well, thank you!
  • CHS
    CHS Posts: 181  Master Member
    edited July 2018
    Hi @Mikko
    Cooldia has uploaded LTE firmware at 5 June. here
  • Aldrich14
    Aldrich14 Posts: 1  Freshman Member
    May have I the newest firmware for LTE, Mine is down after an upgrade to: LTE FW : ALT3100_05_00_02_00_81_MS
    modem FW: V1.00(AAKO.9)
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,388  Zyxel Employee
    100 Answers 1000 Comments Friend Collector Seventh Anniversary
    Hi @Aldrich14
    LTE firmware version ALT3100_05_00_02_00_81_MS is the latest one.
  • JMC
    JMC Posts: 1  Freshman Member
    Hi
    Cloud you please send me the newest lte firmware too?
    Steffen
  • Zyxel_Stanley
    Hi @JMC
    I will send you firmware by private message. Please have a check.
