Turn off 5 GHz
AAltzar
AAltzar Posts: 2 image  Freshman Member
edited November 2023 in Nebula
I'd like to turn off the 5 GHz band and only use 2,4 GHz. How?
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 516 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    edited October 2022 Answer ✓
    Hi @AAltzar,
    We found both NWA55AXE registered under your account are managed by Nebula.
    You can configure the specific SSID band setting by following the below path on Nebula:
    Nebula >> Left sidebar “Access point” >> SSID settings
    1.      If the simple mode is activated, please disable it first.
    2.      Find the SSID you want to modify (We use SSID “Demo” here to demo for you), and click the “Edit” button in SSID advanced settings section.
    3.      Scroll down the page, uncheck the 5GHz and 6GHz band select box then click the “Back” button.
    4.      Check the Band mode, then click the “Save” button to keep the modification.
    5.      Wait until the configuration status of the AP are “Up to date” to ensure the settings are applied to the AP. (If there is no configuration status showing up, please check the list-icon button on the right side, and select the configuration status select box)
    Nebula >> Left sidebar “Access point” >> Access points
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • AAltzar
    ... my device is NWA55AXE
  • Zyxel_HsinBo
    Hi @AAltzar,
    Thank you.
    Zyxel_HsinBo
    Untitled Image
Nebula Tips & Tricks
