NWA50AX
I do not have nebula CC. I use the nebula App on my smartphone and this is where something seems blocked as I am unable to change the scheduling option.0
Hi @Mitch
In the Nebula mobile App, the schedule setting is at the WiFi section, you can change the schedule at WiFi > WiFi Detail > Advanced Settings > Schedule > Select Schedule. However, the schedule configure in the mobile app is just supported the basic setting. For more options, you may login to the Nebula CC website(nebula.zyxel.com).
If you still can’t access the schedule setting, please help me to check that your permission in your org/site, it located at Settings > Admin, only the admin who has Site(Full) / Organization(Full) level has the permission to access and modify the setting.
KayKay
I do have full permission and still can’t modify the schedule setting. Right now it is stuck in weekdays only.thanks for yr help.0
Hi @Mitch
As we didn’t meet the same situation with you, can you help us to enable Zyxel Support at Nebula CC website > Help > Support request, and provide your org/site name, we will help you to do a further check.
Kay
Kay
- 588 USG FLEX H Series
- 477 News and Release
