Will NAS540 and APC 700VA with PowerChute USB port support Auto Shutdown?
Heli
Hi I'm considering to buy new UPS for my NAS540 model
and just found out the Auto Shutdown function when the UPS capacity lower than designed percentage
and I found APC 700VA model with PowerChute USB port
so will both devices are compatible? can I use Auto Shutdown function?
The Nas do support the feature.
But they're not guarantee about which UPS would work
Though the Zyxel only test for the model APC Back-UPS ES 500.
I think other UPS should work too.
How do you feed back the status from the UPS to the NAS540?
I cannot find any contact marked for it. But the software i aware of that there is no signal from any UPS.0 -
You can refer to the User Guide
https://download.zyxel.com/NAS540/user_guide/NAS540_V5.21_Ed4.pdf
On Ch11, Page 171, the settings are on Control Panel> Maintenance > Power > Power Mgnt0
- 588 USG FLEX H Series
- 476 News and Release
