Upgrade disks in NAS320S
IERnStL
I have a NAS320S and want to replace the 4tb disks with 8tb disks ...
I don't want to save what lingers on the 4tb drives because that data has been copied off ...
I simply want to replace the 4TB with the 8TB drives ...
Can I simply shutdown the NAS, remove both old (4tb) drive, then insert the 8tb drives and power up the NAS and setup the new drives?
Thanks in advance
Roy
Thanks in advance
Roy
Yes, you can do it. Just move out the disk and plug in new one to create volume.
If you have backup all the files, and the 4TB disk need to do other using.
You can delete the volume first and shutdown the NAS then remove the 4TB disk from NAS.0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
