USG20W-VPN: Problems establishing Wifi connection / spontaneous reboots
Hi gentelmen, I face the same problem I think. There wireless connection and AP stops in15-20 minutes. I have firmware 4.32. Is there any way to solve with new firmware?0
I am having an issue where the WiFi goes down at a site running 4.32/4.31 and it worked great before. This is a USG60W. Is there some updated software that fixes this?0
Hello, I have problem with the Wlan too, WLAN Tab not appear I have upgraded latest firmware V4.32.
Thanks0 -
Zyxel_Stanley said:0
Hello, please also send me the new firmware. Thanks
Hi @jepper
According WiFi stability issue you can try these firmware first:
USG20W-VPN:
https://www.dropbox.com/s/4gwxkbo4o0ohjx4/431ABAR1ITS-WK29-r84920.zip?dl=0
USG40W:
https://www.dropbox.com/s/beuwl75oi7hxmo3/431AALB1ITS-WK29-r84920.zip?dl=0
USG60W:
https://www.dropbox.com/s/j5e4xh9owjdpa23/431AAKZ1ITS-WK29-r84920.zip?dl=0
We are having a similar problem on the most up to date firmware. The problem seems to only happen when I have multiple wifi networks in operation. For example, I have 1 network for all of our comptuers and a second for the credit card machine that is on an island. I only have problems when there are 2 active wifi networks. Please send me update firmware as well. This is disrupting our business0
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 116 Nebula Status and Incidents
- 6K Security
- 391 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
