LTE3301-M209 WiFi connection
tvvsys
I have 4 devices connected by WiFi. 2 of them (ipad mini and Samsung A51) work fine. But 2 (Xiaomi smartphone and Asus notebook) have problem. Frequently they say "no internet", and even cannot access 192.168.1.1, although WiFi connection is established and other connected devices work without problem. Rebooting router helps, but for some time only.
Hi tvvsys,
Please follow the steps below to clarify the situation when the issue happens:
1. Does the Xiaomi smartphone and Asus notebook have an IP address when the issue happens? You may type "ipconfig" in Command Prompt to see if the Asus notebook has an IP address.
2. Access the LTE3301-M209's user interface by ipad mini or Samsung A51, and check if the MAC address of the Xiaomi smartphone and Asus notebook is on the UI pages?
3. If both question 1 and question 2 have an IP address for Xiaomi and Asus, compare if the IP addresses shown in question 1 and question 2 are the same. In other words, compare the IP address that the Xiaomi/Asus has and the IP address displayed on the LTE3301-M209's UI.
Regards,
Bob0 -
Thank you, Bob!
When problem occurs, Asus cannot connect to router, so it has no IP address. In control panel/wireless connection it says "attempt to check fir authenticitt" (may be not exact translation). In the same time Mi 11 is connected to router but without internet access. IP addresses are the same in router UI and smartphone connection details. Previously I have fixed IP addresses on router for each device.0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
