NWA50AX not upgrade and sync with all access point
NWA50AX not upgrade and sync with all access point, in ther zyxel site last firmware il 6.25, i try manual update but not work Accepted Solution
Because the latest version V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario, the Nebula Firmware available status will display Upgrade available if device running non V6.29P0 firmware and can’t be upgraded.
We’ve checked your running version is stable, you can keep use without worries and please ignore if you received upgrade available message.
More information: https://community.zyxel.com/en/discussion/14786
Thank you
Regards,
Bella
I have the same issue with 3 of my NWA50AXs. Checked the request support option in hope to get some assistance.0
We’ve received your information and will check for you.
Once any observation, we’ll update you as early as possible.
Thank you
Regards,
Bella
Thank you
Regards,
Bella
- 441 Beta Program
- 533 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
