NWA50AX not upgrade and sync with all access point
Nikibasso94
Nikibasso94 Posts: 1 image  Freshman Member
edited November 2023 in Nebula
NWA50AX not upgrade and sync with all access point, in ther zyxel site last firmware il 6.25, i try manual update but not work
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    Hi @Nikibasso94 @tsnbroken
    Because the latest version V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario, the Nebula Firmware available status will display Upgrade available if device running non V6.29P0 firmware and can’t be upgraded.
    We’ve checked your running version is stable, you can keep use without worries and please ignore if you received upgrade available message.
    More information: https://community.zyxel.com/en/discussion/14786
    Thank you
    Regards,
    Bella
Nebula Tips & Tricks
