USG 100 Flex and German Magenta IPTV
@Zyxel_Jeff
I tested with
Zyxel USG FLEX 200
Firmware 5.31(ABUI.0)
ISP Deutsche Telekom AG
Minimal Topology, one Device on LAN 1
WAN pppoe with VLAN 7
Im currently in Nebula Cloud Mode. But I have my configuration saved. As I said before, I will look into this mess a second time but first I would like to know if there is a SSM implementation...
@Niro96 did you get any further and possibly got it to work ?0 -
Hi @FelixSchneider
Currently, we don't support IGMPv3 over PPPoE and SSM(Source Specific Multicast ) features.But we will transfer your requirement to our ideas for our future development, thanks.0 -
Hello @Zyxel_Jeff,
Thanks for this definitive answer, rather unfortunate that Magenta TV with Multicast won't work.
Looking forward to your solution in the future.
At that time I had received a special firmware from the support. This has activated the multicast in the PPOE connection. And then it worked.
Hello @Niro96
May I know what is the special firmware version? Once you updated the special firmware, can you use IPTV to play streaming video and switch channels normally?0 -
Hello Jeff,I got the firmware via Dropbox. When I installed it, German Magenta TV worked on all channels without any problems. The FW was called DF(510ABUH0ITS-WK02-2022-01-19-211201687D). I still have these.
greetingMarcus1 -
that sounds great, maybe the addition for this feature for a stable Firmware release won`t be that far in the future after all @Zyxel_Jeff.
@Niro96 Im Guessing only working in Self Managed mode or does it even work in Cloud Mode (NCC) ?
Greetings
Felix0 -
Hi @Niro96
OK, thanks for your response. When you use the DF(510ABUH0ITS-WK02-2022-01-19-211201687D) are there any error messages showing "old IGMP version'"? Does Magenta TV box support IGMPv2 also or IGMPv3 only?0 -
I always got an error message related to the IGMP protocol. You are using an old version. Magenta TV only uses IGMP v3. Despite this message, it worked without problems. I cannot answer whether this firmware also works in cloud mode.
Hi @Niro96(1). When you using the DF, did you try to connect Magenta TV box behind your USG Flex 100 physical LAN port directly, rather than switch?I mean the topology is ISP Router -> USG Flex100 -> IPTV box and is it working?And this topology ISP Router -> IPTV box and is it working?(2). Could you provide the video or screenshots of the old IGMP version message?(3). Had you confirmed with the IPTV provider, why there are old IGMP version messages?0
- 435 Beta Program
- 183 Nebula Ideas
- 120 Nebula Status and Incidents
- 6.2K Security
- 439 USG FLEX H Series
- 299 Security Ideas
- 80 Switch Ideas
- 276 Service & License
- 433 News and Release
- 91 Security Highlight
