USG 100 Flex and German Magenta IPTV
13»
  • Niro96
    Niro96 Posts: 56 image  Ally Member
    Hi Jeff, I currently don't have a magenta box anymore. But I can tell you about the past.
    1. First I have the modem VMG3006 D70A and then USG Flex 100 which dials in with PPOE. The GS1920-8HPV2 switch was then connected behind the USG Flex 100. The Magenta Box was then installed on this.
    2. I've attached a screenshot from back then.
    3. I asked Telekom. Since I use hardware other than that of Telekom, I didn't get any information. White but from the forum that only version 3 is used.
    greeting Marcus
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,359 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    Hi @Niro96
    OK, thanks for your response to us.
  • Zyxel_Jeff
    @Zyxel_Jeff
    I tested with
    Zyxel USG FLEX 200
    Firmware 5.31(ABUI.0)
    ISP Deutsche Telekom AG
    Minimal Topology, one Device on LAN 1
    WAN pppoe with VLAN 7
    Im currently in Nebula Cloud Mode. But I have my configuration saved. As I said before, I will look into this mess a second time but first I would like to know if there is a SSM implementation...
    @Niro96 did you get any further and possibly got it to work ?
    Hello @FelixSchneider
    Currently, our firewall hasn't implemented PIM-SSM and SSM suites, so we cannot support this feature. We already transfer this requirement to an idea for our future development evaluation. Thanks for your response and assistance for us :) .
