NR5101 4G doesn't work with external antenna
Dannedk
I just received a Zyxel Nebula NR5101 that I bought to change out my 4G router. I have the 4G router connected to a 5G antenna and get about 45mbit down and 15mbit up. I connected this new router and now get 10mbit down and 2 up. A serious disappointment. I quickly realized that the router only uses the internal antenna for 4G and not the external antenna. I've now read that this is actually how this router functions. Can this be true? For this extremely expensive router and not even the function of 4G to the external ports? Is there really no way to disable the internal antenna and use all the frequencies of the external antenna? Any update that fixes this available?
The NR5101's external antenna and device ability support 3300-4200 MHz.😭
https://support.zyxel.eu/hc/en-us/articles/5719448327314-NR5101-How-to-use-the-External-Antennas
Thanks for the info!
What a useless product though... Will definitely send it back. And a price recalibration to about 150usd instead of 500 may be in place for this router...0 -
Check PM....0
I experienced the same total bafflement learning that the external antenna ability is only for the high band!
It was sold in a package deal with an external antenna. No warnings anywhere about this limitation.
Any suggestions for a product that doesn't have this limitation?0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
