Recent NSG100 firmware update kills device?
Peppino
Peppino Posts: 186 image  Master Member
First Comment Friend Collector Eighth Anniversary
I pressed the update now button on one of the NSG100 we have here, and apparently it bricked the appliance. Any known bug or issue others might have noticed?
Eventually a recovery SOP for mine?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,869 image  Zyxel Employee
    Hi Peppino,
    We haven't received any reports about the firmware upgrade killing the device.
    Could you share your service impact on what appliance is bricked?
    • Such as you can not change any configuration on Nebula?
    • Or your network service has been impacted?
    • Can it be recovered by reboot?
    Also, please help to check if you can ping the NSG LAN 1 interface or not.
    If yes, please follow the file I PM you to upgrade the firmware.
    Zyxel Melen
  • Peppino
    Dear Melen,
    Thank you for the help, I will be able to check it on Monday only, as the firewall is locked into a server room, and the guy is on holiday. I will keep you posted.
    Have a nice weekend!
Nebula Tips & Tricks
