2 x Multy M1 in Bridge Mode with ethernet
paulleeuw
is this possible. 2 x multy m1 in bridge mode. both connected to the same ethernet LAN. will they "work together". will client roaming work ?
Hi @paulleeuw
If the Multy M1 set up as bridge mode separately, that means these two Multy devices work independently. Some models of the client may be a sticky station that could not roam or in low aggressiveness for roaming. In this scenario, Multy would not kick the client when the client is near the other Multy which signal is better.
ok, i now have two NAP102 with nebula basic. They work together. I hoped the M1 would doe the same0
Multy M1 need to set up the mesh to make it work, but to do the mesh, Multy M1 devices cannot put in the same network subnet. The satellite need to put behind the Main one.1
Hi @Marcos55P
Could you provide more information about your network topology?
What do you mean a similar kind of issue?
Please describe more details about it.0
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 310 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
