NWA50AX firmware V6.29(ABYW.0)
2»
  • apar74
    apar74 Posts: 1 image  Freshman Member
    I am having the same issue, can you please guide how to downgrade to the stable version?
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 517 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - WLAN
    Hi @iambenmitchell,
    Because the latest version V6.29P0 is temporarily removed due to it has been verified it may cause repeated reboot in worst case scenario,
    The Nebula Firmware available status will display Upgrade available if device running non V6.29P0 firmware and can’t be upgraded.
    We’ve checked your running version is stable, you can keep use without worries and please ignore if you received upgrade available message.
    Thank you
    We found the AP registered under your email is already rolled back to stable version.
    Let us know if there another assistance that we could help with.
    Sorry for the inconvenience.
    Zyxel_HsinBo
    Untitled Image
  • iambenmitchell
    iambenmitchell Posts: 7 image  Freshman Member
    Hi @Zyxel_HsinBo
    Has the issue been fixed? I like to keep my firmware up to date but because the firmware is still locked I don’t know if a new firmware is out
  • Zyxel_HsinBo
    We are working on new firmware release progress and expect to release this month.
    Please help us to keep an eye on the post from the link below, we'll update if anything is in new progress:
    https://community.zyxel.com/en/discussion/14786
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • Tronikx
    Tronikx Posts: 1 image  Freshman Member
    hello, i'm having troubles with 6.29 too, and i'm in nebula. what i have to do to roll back to 6.25? thanks.
Nebula Tips & Tricks
