LED schedule
iambenmitchell
iambenmitchell Posts: 7 image  Freshman Member
Hi all,
I am a residential user and have an AP upstairs where the bedrooms are. However the LED light started to get annoying so I turned it off in nebula.
I noticed there’s no ability to schedule the LED light to be on or off, and there’s also no ability to specify it by device.
I would like to see two new things added to nebula:
1. Ability to change the LED light per device
2. Ability to set a schedule per device on which times the LED should be off.
As an example: “Turn LED off on bedroom AP between 10PM and 9AM” — but keep the LED on the hallway AP on 24/7
The Hallway LED provides a nice amount of light to help people see in the dark if they’re say getting a glass of water at night so that’s why I’d like to be able to control the LED per device.
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,315 image  Zyxel Employee
    Hi there,
    Thank you for your idea. We’ll evaluate this feature thoroughly in the next time.
    Please follow us to know more about new function and feature.
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
