NR5101 vs NR5101 Nebula
Tuva
Tuva Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
Hello, I am looking for a 4G & 5G router for my home, and can choose between NR5101 vs NR5101 Nebula which are available for the same price. What is the difference, and why should I choose one over the other?
  • Noddy
    Noddy Posts: 67 image  Ally Member
    First Comment First Answer Friend Collector Third Anniversary
    Nebula is just a centralised web console for configuring and monitor multiple devices over multiple locations, etc.  For a home device, I'd personally say you do not need it.  You'd just manage the device via the normal built-in interface on the Router.  Thanks.
  • Noddy
  • stearv
    stearv Posts: 1 image  Freshman Member
    shall I skip the Nebula framework?
  • jgroves56
    jgroves56 Posts: 3 image  Freshman Member
    How do you disable nebula web console and only use router interface?
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    I use NR7101 non Nebula version but i have Nebula firmware installed.
    I just untick Nebula, see pic.
    I don´t know if it looks like this in NR5101 interface….
  • Mayone78
    Mayone78 Posts: 46 image  Freshman Member
    First Comment Friend Collector Second Anniversary Community MVP
    So @selberg you confirm that I can install Nebula firmware on a non Nebula NR7101? Is there any particoular step to follow?
    Thank you!
