status AP - green on white icon?
The green icon means that AP is online and it has an Ethernet uplink.The green-on-white icon means that AP is online and it has the wireless uplink and it doesn’t have the Ethernet uplink.About the AP status on NCC, you can refer to this articleNoted: If your AP status is with the green-on-white icon, but your AP connects to the Ethernet cable, you need to check the cable and the uplink to the Internet.ThanksJay1
thank you!!1
- 243 Nebula Ideas
- 6.9K Security
- 793 USG FLEX H Series
- 391 Security Ideas
- 88 Switch Ideas
- 59 Wireless Ideas
- 7.3K Consumer Product
- 327 Service & License
- 530 News and Release
- 104 Security Advisories
- 5.4K FAQ
- 91 About Community
- 122 Security Highlight
