status AP - green on white icon?
edited November 2022 in Nebula
what is the difference between green icon and green on white icon?
  • Posts: 227  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 5 Answers
    edited November 2022 Answer ✓
    The green icon means that AP is online and it has an Ethernet uplink.
    The green-on-white icon means that AP is online and it has the wireless uplink and it doesn’t have the Ethernet uplink.
    About the AP status on NCC, you can refer to this article
    Noted: If your AP status is with the green-on-white icon, but your AP connects to the Ethernet cable, you need to check the cable and the uplink to the Internet.
    Jay
Welcome!
It looks like you're new here. If you want to get involved, click on this button!
Welcome!
