Virtual Interface USG 100
In a network with additional public ip addresses, I have installed a usg 110 with static public ip address in WAN1. The configured address is 84.253.177.171/29. The gateway is 84.253.177.169.
I need to publish a local network machine with ip 192.168.1.1 on the internet. I want to configure the usg so that when an http request arrives on address 84.253.177.172 on port 80 it turns it to address 192.168.1.1. I created a virtual interface with ip 84.253.177.172 but the NAt on the local ip doesn't work. Am I preceding correctly? Best regards 0
Hi @Giuseppe,The port 80 is the default service port for HTTP on USG110. You can either disable HTTP in System > WWW > Service Control > HTTP or set another port for this service port.Besides, you also need to add a security policy rule after NAT rule is created. Go to Security Policy > Policy Control and add a new rule as follows.From: WAN, To: LAN1, Destination: IP address of local network machine, Service: 80, Action: allow
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
