Why can't I turn off DNS threat filter, nags to purchase Gold
I have about had it with the limitations of Nebula. Ready to scratch and go back to native interface. Cannot maintain stable IPSec connection, Cannot setup Vlan/VPN Snat and now this. The device came with UTM pack for a year, Nebula Pro, but I am still crippled trying to do anything real in this kiddie interface.
It shows "enabled" but it is not, because its not on Gold. It cannot currently be changed to "disabled". UI issue, I will expect it will be resolved in future edition.0
Had you installed the UTM security pack or Gold security pack license on your device? As I know this is a licensed feature, I don't have it so I also see the popup notification just like yours.
Some people might think that "nag" is not the right word, which should be "ad". Kinda.0
Hi @Rix,If you don't have Gold Security Pack license, the function will not be provisioned from nebula to the firewall even if it shows "turn on" on the GUI. It means the function in the running configuration file on the firewall is "turned off". We will discuss the UX design and display status of this page internally.0
Such unwise choice of UI. How could it possibly be accessible a swich in the UI that the user cannot enable it?Zyxel_Emily said:Hi @Rix,If you don't have Gold Security Pack license, the function will not be provisioned from nebula to the firewall even if it shows "turn on" on the GUI.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
