NAS326: Restore Deleted JBOD Volume
So i guess it's testdisk now... Or do you see something where i made an error?0
When using --build, you'll have to provide a --data-offset=16, else the raid header space will be used as well.SpamMaster50000 said:So i guess it's testdisk now... Or do you see something where i made an error?
Hmm, not goodthe problem was that my version of mdadm doesn't yet know the data offset option~ # mdadm --build --assume-clean --level=linear --raid-devices=2 --rounding=64K --data-offset=16 /dev/md2 /dev/sda3 /dev/sdb3
mdadm: unrecognized option '--data-offset=16'
Usage: mdadm --help
for help
Can i use losetup instead?
SpamMaster50000 said:Can i use losetup instead?Good thinking! Yes, that should be possible.losetup /dev/loop1 -o 8192 /dev/sda3losetup /dev/loop2 -o 8192 /dev/sdb3mdadm --build <arguments> /dev/md2 /dev/loop1 /dev/loop2
- 441 Beta Program
- 293 Service & License
- 461 News and Release
