LTE5398-M904 - ZySH command to reboot LTE connection
acastelli
i have a LTE5398-M904 router. My telephone operator schedules an IP change every 4 hours which consists of a disconnection of about 12 seconds, enough to disconnect from the vpn or from a call conference.
I would like to understand if there is a way to force the reconnection of the LTE network to avoid being disconnected at particular times of the day. The idea would be to run a script that connects in ssh and (for example) selects an unavailable band in my BTS or disable and re-enable wwan0.
I have not found documentation on ZySH commands. Can someone help me?
Thank you
Hi @acastelli,
I am experiencing something similar, did you ever work out a solution?0 -
@Zyxel_CPE could you please send me instructions on how to ssh into the router?
I am using:
ssh admin@192.168.1.1
I tried password 1234 and my http login's password, but neither is working0 -
for anyone bumping into this: firmware upgrade did the trick0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
