NAT from source IP by FQDN
When making a NAT rule for Virtual Server your able to select for source IP a FQDN which would allow a dynamic connection by given FQDN to IP to match the NAT rule.
WILDCARD FQDN are not selectable.
NAT <> Virtual Host.NAT chews only IPs, no hostnames.0
You're probably right.
I'll gladly read the lecture, if you will write it when you'll have enough time.
Thanks Peter, do you refer to security policy? It's the only rules where I can specify a source IP as FQDN, but if I set this I can't set the dest. port and I wouldn't that this has effect for all NAT because I have some port forwarding without restriction and other with this source restriction.
Thanks in advance
The idea is for the NAT rule to have select traffic by source FQDN go to a port like port 80 at say 192.168.0.2 but with another rule below for port 80 to have any other traffic go to 80 192.168.0.80
there is a way you can do the above but needs a VLAN switch and another USG and not with NEBULA
if your not needing that then you can use security policy
- 212 Nebula Ideas
- 549 USG FLEX H Series
- 341 Security Ideas
- 295 Service & License
- 469 News and Release
