NR5101 5G indoor router impossible to reset !
pinda
the NR5101 5G indoor router is impossible to give a factory reset, the reset button does not function 5s/10s/15s/20s/1hour nothing works. any other options ?
Hi Pinda,
Is it because you forget the login password, and you still can't log in after pressing the reset button?
May I know the serial number of your NR5101?
You can find the serial number at the bottom of the NR5101.
Regards,
Bob0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
