LTE firmware for SBG3600
Hello @Zyxel_Stanley
I'm running firmware SBG3600-N000_V1.00(AAKO.9)C0
and LTE firmware ALT3100_04_05_06_10_B8_LO
is there any better / improved LTE firmware version available ?0 -
Hi @Ron
There is a latest version for LTE firmware is ALT3100_05_00_02_00_81_MS
I will send you firmware by private message.
Am using SBG3600N with LTE Firmware ALT3100_04_05_06_10_B8_LO, & System firmware V1.00(AAKO.6). Am having Bandwidth related issues. Pls. advice which is the latest stable firmware upgarde.
Hi @Menon
The latest LTE firmware is ALT3100_05_00_02_00_81_MS.
You can download firmware by this link:
https://www.dropbox.com/s/2nbtcihydtwnscs/firmware_ALT3100_05_00_02_00_81_MS.bin?dl=0
Thank you. A quick query, should I patch V1.00(AAKO.8) & V1.00(AAKO.9). Or can I straight away patch V1.00(AAKO.9) from V1.00(AAKO.6). Thanks.0 -
Dear all
I’m facing exactly the same issue and would be more than happy to get the newest LTE firmware to solve the Issue.
I got it but when I upload the Router is rebooting and is still showing the old version. :-(
If I try to update the firmawe V1.00(AAKO.8) to AAKO.9 it failes with the info "Image uploading failed. The selected file contains an illegal model id."
Thanks a lot for your help
Thomas
Dear support,
I have downloaded the LTE firmware ALT3100_05_00_02_00_81_MS, from your Dropbox link.
But I have the same issue as SwissTom,
upload of the firmware looks good, but after the reboot, I do have the old version: ALT3100_04_05_06_10_B8_LO,
do you have any solution?
PS my firmware version is: V1.00(AAZE.9)
Thanks in advance,
KR
HI @Zyxel_Vic ,model SBG3600-N000 / V1.00(AAZE.9)I have downloaded the LTE firmware ALT3100_05_00_02_00_81_MS, from your Dropbox link.
when upload of the firmware looks good, but after the reboot, I do have the old ALT3100_04_05_06_10_B8_LOso i test to enable lte with ssh shell.. but when use lte command crash.....I test to restore factory of device and upload lte firmware but i've same problem....The big problem is that lte don't work... I hope with new firmware a solution....
- 215 Nebula Ideas
- 569 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
