pla6456 ethernet
diplexer
Why does my pla6456 ethernet show ETHB as 100 and not 1000 even though I'm connected to a gigabit router with a 300Mbps internet connection? Using cat5e cables.
| Ethernet | |||||||
| External Interfaces: | |||||||
| Interface | Speed | Duplex | Interface Type | Mode | Internal PHY | Link | |
| ETHA | 100 | FULL_DUPLEX | RGMII | MAC | NO | NO | |
| ETHB | 100 | FULL_DUPLEX | SGMII | MAC | NO | YES | |
Hi @diplexer
Please check the router above the PLA if the port speed has been limited to 100M by the router.
If is is not able to change the port speed with the router, you can try to switch other ethernet cable and check if the ETHB still show 100 port speed.0
- 220 Nebula Ideas
- 603 USG FLEX H Series
- 482 News and Release
