Country in radio settings
xeoncloud
xeoncloud Posts: 1 image  Freshman Member
edited November 2023 in Nebula
Any suggestions on how to change the country on my radio settings.
Currently it is saying US, even though I am in the UK.  When I try to change it and save, I am displayed a error that one AP is detected as in the US.
The nebula website also shows my login to be from the US.
There appears to be a handful of GEO-IP services which are incorrectly reporting my IP's location.  The vast majority of them are OK but it seems that Zyxel is using one of the ones that are not maintained correctly.
  • Zyxel_Bella
    Zyxel_Bella Posts: 560 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - Switch 50 Answers
    edited November 2022
    Hi @xeoncloud
    Welcome to Zyxel community!
    As you mentioned you’re using Nebula, here is the path to change country code on Nebula.
    Please go to Access point > Configure > Radio settings > Country then select United Kingdom as your location.
    The AP will follow the settings to apply corresponding radio regulations.
    If you still have problem, could you please provide error screenshot or enable the Zyxel support at Help > Support request > Invite Zyxel support as administrator, save the changes for us to check.
    [Nebula] How to turn on Zyxel Support Access?
    And provide the Org and Site name, thank you.
    Thank you
    Regards,
    Bella
Nebula Tips & Tricks
