No email report from USG200
Hi support,
I have a USG200.
I would like to get a daily email report from my USG.
I copied pasted my google credentials from Firefox to the configure email daily report page.
Unfortunately, when I click on the "Send report now", nothing is received and nothing is the send mailbox folder.
What's wrong, is it a bug? Is there a custom configuration for the google smtp settings?
Kind regards
Mat
Hi @mat17,
Greeting forum, For Gmail notification, you have to create application password first.
Please kindly find the following FAQ.
https://community.zyxel.com/en/discussion/14003/how-to-set-up-gmail-for-gateway-mail-notification#latest
Thank you
Kevin0 -
Hello Kevin,This is what I've done so far and still no email notifications.Can't understand.Kind regardsMat0
Hi @mat17,
1)Please kindly check SMTP doman can be resolved and capture packets. There will packtes out when send report.
If all of settings looks well, May we schedule remote session to check the issue?
Kevin
Thank you
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 496 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 49 Wireless Ideas
- 286 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
