Bug: DNS no longer delivers internal entries
Hello dear zyxel support team!
DNS entries added via firewall settings are suddenly no longer delivered. Nothing was changed in Nebula. After I added a new entry in Nebula under Firewall settings, it worked normally again. As firewall I have a USG Flex 200.
Thanks!
Thanks!
Hello @baba,Since it works normally now, and we didn't see any abnormal server logs recently. Please help us to collect information when it happens again.We need two diagnostic info files and the timestamp when the problem appears and disappears.1. collect the diagnostic info when the problem occurs2. collect the diagnostic info after re-push the DNS entries configure. (add a new entry or re-enable)How to collect diagnostic info?Login to local web gui, the username/password is support/side-wide general setting password.Thanks,James0
Hi @Zyxel_James
the error is back again. It can't be fixed anymore by adding a new entry. All entries are shown in Nebula, but not delivered via dns server. I've activated Zyxel Support Access in nebula and downloaded a diagnostic info from the usg flex 200.
Thanks!0 -
When saving the "Firewall settings" page i will get the following error:
Hello @baba,Currently, the Nebula CC webpage is suffering an unexpected outage incident, this issue is related to the incident too. We already posted an announcement on our official forum, any progress will be updated there too, please refer toI will keep you updated when it's fixed as well.Best regards,James0
Hi @Zyxel_James
the issuse is marked as resolved but my error is still there. I saw you had added an entry zyxel.test.com which didnt fix the problem.
Thanks!0 -
Hello @baba,It's an issue with DNS address record settings, we're working on it.If you need the DNS entries settings urgently, I can help you to add them first, please provide the DNS entry settings to me through PM.James0
Yes need them urgently. The entries are shown in nebula under "Firewall settings". I sent you all entries via PM. Thanks!0
@Zyxel_James all entries are deleted again, please help me0
I think it will be resetted at some time. Can i do add entries on my own?0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 454 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 278 Service & License
- 435 News and Release
- 91 Security Highlight
