Setting up a new user does not work
I would like to set up an additional administrator in NCC.
For this I have created under: Organization-wide => Cloud authentication to create a new user.
Under the entered e-mail address the new user gets a mail with his access data and a link.
Unfortunately, after logging in, this link leads to a page: "Update your account information".
On this page the data can be changed, but there is not a "Continue" button.
How do I continue?
According to my understanding, the user must first be logged in and confirmed to be able to enter him later as admin.
Hi @AchtFox,
If you want to add a new administrator for your organization, please go to Organization-wide > Administrators to add.
The Cloud authentication is to create an account for login the SSID or the Captive portal.
Hi Melen, Thanks for the quick reply. But I am not getting anywhere with it.When I set up the new admin it does not ask for a password. Example screenshot 1
After clicking on Create admin the user gets an email at the email address [email protected]. But also here is no password to find. See screenshot 2.
Beim Versuch sich mit [email protected] einzuloggen wird aber ein Passwort verlangt. Siehe Screenshot 3.
What is to do?
Thank you for your help. Regards Wolfgang Joschko
Ouer plant has app. 30 WLAN Accespoints from Unify, 5 Webcams from Unify and 12 Switches. We are now switching from Unify to Zyxel. All switches now from Zyxel.0 -
Hi Melen, it has worked. Thank you for your support.1
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 907 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
