no acces ugs20
Hello
I have 2 UGS20 routers.
since there is a certificate problem, I go through the internet explorer browser
but I can't access one of them even with internet explorer
message INET_E_DOWNLOAD_FAILURE
I can't log in using SSH either.
I think that the 2 boxes do not have the same firmware
do you have another tool to do this?0
Best Answers
Hi @baudetd
It seems you enable the feature on the path Configuration > System > WWW > Service Control > Authenticate Client Certificates and your PC has not imported a trusted certificate yet, so you cannot login the device.
Please connect your PC(with Tera Term or PuTTY, the baud rate is 115200) and device with the console serial cable. Then login to the device and enter the below CLIs to disable this feature.
Router > configure terminal
Router(config)# no ip http secure-server auth-clientHere are some users who encountered the same problem(link1, link2).
Hi @baudetd
Yes.Is it possible to check with the serial console if authentication is enabled?
Yes.Is it possible to do this over ssh?
Hi @baudetd
hello
thanks for the reponse
it's surprising that it's activated because I'm the only one to connect to it and I was still accessing the interface a few weeks ago
Hi @baudetd
I connected in serial but I can't log it because it asks me for a user name and password, my credentials are not working same in ssh However, here is the message I get when I log in ALERT!!image filesystem usage: 99%12K /rw/lost+found1.0K /rw/etc_writable/budget100K /rw/etc_writable/zyxel/conf101K /rw/etc_writable/zyxel4.0K /rw/etc_writable/hwclock_log833K /rw/etc_writable55M /rw55M /rw
HelloI was finally able to access the interface of the USG 20 routerI was able to update the firmwarefirmware download from website (released date: 2016-11-22)
however, I did not find the latest firmware
because I have another router that already has the latest version
(released date: 2016-11-30)
I found this link which allows to download the *.bin filebut it doesn't work
thanks0 -
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
