GS1900-8HP PoE Issue
  • Zyxel_Jason
    Zyxel_Jason Posts: 430 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula Zyxel Certified Sales Associate
    Hi @BjP,
    I haven't received the tech support files from you via private message.
    May you send again?
    Thanks.
    Jason
  • sledge121
    sledge121 Posts: 6 image  Freshman Member
    Friend Collector
    I gave up in the end and bought a Netgear S350.
  • ZyxelHamburg2023
    ZyxelHamburg2023 Posts: 6 image  Freshman Member
    edited December 2022
    Hi Jason,
    i have the same problem. I tried to upgrade my GS1900-8HP to newest firmware 2.7 - after this i got the error message "POE init failed"
    Please contact me and i can provice the tech files - thanks
    BTW: No problem by upgrading my GS1900-10HP
  • ZyxelHamburg2023
    Hi, my problems are bigger as i thought.
    I tried to use any other PORT or use another POE device - but since upgrading to 2.7 no one of my POE device is working.
    Whats happend ?
    Added Report:
    20
    Jan 01 2022 00:00:16
    PoE
    emerg
    PoE Set CMD 13 failed
    21
    PoE
    emerg
    PoE Set CMD 22 failed
    22
    PoE
    error
    PoE Failure: Set port power up mode
    23
    PoE
    emerg
    PoE Set CMD 25 failed
    24
    System
    info
    Sysinfo variable 'resetdefault' is set to value '0'
    25
    Jan 01 2022 00:00:15
    System
    notice
    RESTART: System restarted - Warm Start
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,616 image  Zyxel Employee
    Hi @ZyxelHamburg2023
    Welcome to the Zyxel community!
    Are you using V2.70 patch 3 firmware to upgrade your GS1900-8HP and then getting the "POE init failed" message?
    Zyxel Melen
  • ZyxelHamburg2023
    Hi Melen, yes of course. Downloaded the latest version from zyxel download center - named"GS1900-8HP_2.70(AAHI.3)C0"
    - Upgrade process running pretty well
    - after reboot "Error Message - POE INIT Failed"
    => Downgrade is possible but the problem still there:
    - no error message unter 2.6 BUT
    - no one POE Device will work - it looks like the POE Init "died" ?
  • Zyxel_Melen
    Hi @ZyxelHamburg2023,
    Based on your feedback, your GS1900-8HP has PoE failure. Please check here to submit RMA request.
    Zyxel Melen
  • ZyxelHamburg2023
    ok, already done - RMA created.
  • ZyxelHamburg2023
    I am thrilled.
    Already today the replacement device reached me.
    That is perfect customer service for me.
    I am glad to have chosen "Zyxel" products.
    THANK YOU
  • tomdv
    tomdv Posts: 1 image  Freshman Member
    Dear my Zyxel GS1900-10HP broke down the POE ports are no longer working.
    It gives the message "POE INIT FAIL".
    As it is out of warrenty I have opened it and found that a diode was broken on the PCB in the 3.3v switching power supply part that provides power to the Broadcom POE chip.
    As a consequence of this TP14 doesn't measure 3.3v
    I replaced the diode (B1100 SMD diode) and now my beloved switch is working 100% with POE.
    For anyone out of warrenty and doesn't want to put this otherwise good switch in the trash I hope I could help.
    Greetings
    Tom
