no acces ugs20
baudetd
baudetd Posts: 44 image  Freshman Member
Hello
I have 2 UGS20 routers.
since there is a certificate problem, I go through the internet explorer browser
but I can't access one of them even with internet explorer
message INET_E_DOWNLOAD_FAILURE
I can't log in using SSH either.
I think that the 2 boxes do not have the same firmware
do you have another tool to do this?
Best Answers
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited December 2022 Answer ✓
    Hi @baudetd
    It seems you enable the feature on the path Configuration > System > WWW > Service ControlAuthenticate Client Certificates and your PC has not imported a trusted certificate yet, so you cannot login the device.
    Please connect your PC(with Tera Term or PuTTY, the baud rate is 115200) and device with the console serial cable. Then login to the device and enter the below CLIs to disable this feature.
    Router > configure terminal
    Router(config)# no ip http secure-server auth-client
    Here are some users who encountered the same problem(link1, link2).
  • Zyxel_Jeff
    Hi @baudetd
    Is it possible to check with the serial console if authentication is enabled?
    Yes.
     Is it possible to do this over ssh?
     Yes.
  • Zyxel_Jeff
    Hi @baudetd
  • baudetd
    hello
    thanks for the reponse
    it's surprising that it's activated because I'm the only one to connect to it and I was still accessing the interface a few weeks ago
  • Zyxel_Jeff
    Hi @baudetd
    Yes.
     Yes.
  • baudetd
    I connected in serial but I can't log it because it asks me for a user name and password,
    my credentials are not working
    same in ssh
    However, here is the message I get when I log in
    ALERT!!image filesystem usage: 99%12K
    /rw/lost+found1.0K
    /rw/etc_writable/budget100K
    /rw/etc_writable/zyxel/conf101K
    /rw/etc_writable/zyxel4.0K
    /rw/etc_writable/hwclock_log833K
    /rw/etc_writable55M     /rw55M     /rw
  • Zyxel_Jeff
    Hi @baudetd
    You could refer to this link to see how to restore your previous configuration if you forget the login password. Thanks.
  • baudetd
    Hello
    I was finally able to access the interface of the USG 20 router
    I was able to update the firmware
    firmware download from website (released date: 2016-11-22)
    however, I did not find the latest firmware
    because I have another router that already has the latest version
    (released date: 2016-11-30)
    I found this link which allows to download the *.bin file
    but it doesn't work
    thanks
  • Zyxel_Jeff
    Hi @baudetd
    Please refer to this download link then unzip the .zip file to the .bin file and upload the .bin file to your ZyWall USG20 it should be OK, thanks.
