Quality of Service port on NR7101
Joney5ive
Does the 7101 have (QoS), Is it possible to set the (QoS) Quality of Service to port 6050 on the 7101? We are having issues with VoIP dropping calls.
Hello @Joney5ive
The only reference to QoS in the NR7101 user guide at https://download.zyxel.com/NR7101/user_guide/NR7101_Version%201.00.pdf is to WMM (WiFi Multimedia) that follows the ToS field of the IP packets.
Turning this on might help you, if the VoIP packets are marked correctly in ToS with DSCP, i.e Expedited Forwarding (EF), see https://www.networkworld.com/article/2234016/the-qos-expedited-forwarding-ef-model.html .
Nothing else QoS that I can see is available with NR7101.
Kind regards,
Tony0
Hello @Joney5ive
Kind regards,
Tony0
- 439 Beta Program
- 191 Nebula Ideas
- 6.2K Security
- 468 USG FLEX H Series
- 308 Security Ideas
- 82 Switch Ideas
- 281 Service & License
- 440 News and Release
- 4.3K FAQ
- 93 Security Highlight
