NSA320S Metarepository stopped working - try to upgrade from SMP1
Yes, yes, yes!!! You are the best! It works!!!!
So, the telnet backdoor works fine: I've installed it after I bought the NAS. With basic linux knowledge I can edit files, has ssh access, mcedit is much easier the vi :-)
Finally I have edited the /usr/local/zy-pkgs/etc/MetaRepository.conf file and added the repository you've mentined in the previous post: http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/zyxel_fw4_zypkgs/
After a full restart, in the web interface appeared all the installed packages :-)
Thank you very much, you saved me from buying a new NAS.
(Now I'm a bit afraid to install samba2, but this was my original target)0 -
Now I'm brave enough to install Entware-ng and samba as in your forum topic (https://zyxel.diskstation.eu/forum/viewtopic.php?f=4&t=24) and it works for the first try!
I'm so happy now and I'm really appreciate your help!0 -
is there any other repository for zypkgs? http://zyxel.diskstation.eu does not work for me.0
Yes, it works, but you missed a dot. So the correct url:
http://metarepository.tk/Users/Mijzelf/zypkg-repo/
At the moment http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/ works.
Thank you! With your help I was able to update my NSA310S to SMBv2
Hi, does anybody know if this new repository address work?
And one more question, how to copy .zpkg file to the NAS? Which software do you use on Windows 11?
- 588 USG FLEX H Series
- 477 News and Release
