Multi X WSQ50
cbm64
cbm64 Posts: 7 image  Freshman Member
I have a three node multi. One is connected to the PPPoE, another is on an ethernet backhaul. The third is on the WiFi backhaul. I am having an issue with the third, after several factory resets, restarts and a full reset of the mesh it refuses to offer up internet either via ethernet or WiFi. The setup of the node goes fine, it reports a perfect positioning. Testing, reports a useful connection speed to the primary node. An ethernet test to the node shows as not connected both in the Multi app and on a computer. Is there anything else that can be done or is it likely to be faulty?
  • cbm64
    I should note, that it used to work!
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,406 image  Zyxel Employee
    Hi @cbm64
    Could you share what it the firmware on your Multy device and also the app version you're currently using?
    Please send us the feedback on the Multy APP.
  • cbm64
    edited January 2023
    Hi @cbm64
    Thanks for coming back to me @Zyxel_Jerry sorry for the delay in coming back.
    Multi: V2.20(ABKJ.8)C0
    App: 2.5.4.221224
    All multy's are reporting the same firmware. I have sent feedback as requested too.
  • cbm64
    Can't say I am massively happy about the zip files in the feedback being password protected. I have no way of inspecting the data I have just shared. Can you confirm that no personally identifiable data has been collected?
  • Zyxel_Jerry
    Hi @cbm64
    We've received your send feedback.We'll contact you via the email.
