NAS326 - MetaRepository: Download List Fail
andisaraci
Hello all
I keep getting the "Download list fail" message when I try to Retrive the app list from the internet. I even tried to unistall and freshly reinstall the Metarepository.
Here are the configuration and log files
/i-data/1e45b118/admin/zy-pkgs/MetaRepository/zypkg.log
/i-data/1e45b118/admin/zy-pkgs/MetaRepository/ZYPKG_INFO.tgz.log
/i-data/1e45b118/admin/zy-pkgs/web_prefix
http://localhost:59999/
/i-data/1e45b118/.PKG/MetaRepository/gui/MetaRepository/pkgcgi.cgi
/i-data/1e45b118/admin/zy-pkgs/MetaRepository file list
Request: /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz
/i-data/1e45b118/.PKG/MetaRepository/gui/MetaRepository/pkgcgi.cgi: line 646: dirname: Argument list too long
TarHeader
cat: write error: Broken pipe
/i-data/1e45b118/.PKG/MetaRepository/gui/MetaRepository/pkgcgi.cgi: line 646: echo: Argument list too long
failed
HandleZYPKG_INFO /NAS326/zypkg/5.21
FindApp md5sum found /sbin/md5sum
ReadConfig Repositories
Start of block
ftp://ftp2.zyxel.com/+ ZyXEL
/i-data/sysvol/admin/zy-pkgs/MetaRepository Local
End of block
7 start: 14:02:17
8 start: 14:02:17
9 start: 14:02:17
8: FetchZYPKG_INFO http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ 8 Mijzelf
7: FetchZYPKG_INFO /i-data/sysvol/admin/zy-pkgs/MetaRepository/ 7 Local
9: FetchZYPKG_INFO ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ 9 ZyXEL
7: FindApp curl found /usr/bin/curl
8: FindApp curl found /usr/bin/curl
9: FindApp curl found /usr/bin/curl
7: Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_zy-pkgs_MetaRepository_.tmp failed
7: Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/_i-data_sysvol_admin_zy-pkgs_MetaRepository_.tmp failed
7: Failed
7 stop: 14:02:19
9: Fetch ftp://ftp2.zyxel.com/NAS326/zypkg/5.21/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.tmp succeeded
9 stop: 14:02:22
8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKG_INFO.tgz /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
8: Fetch http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/fw5/ZYPKGS /i-data/sysvol/admin/zy-pkgs/MetaRepository/http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp failed
8: Failed
8 stop: 14:02:47
Pushlist...
ReadConfig Pushlist
Start of block
End of block
Blacklist...
ReadConfig Blacklist
Start of block
YouNameIt
End of block
/bin/sed -i s/^YouNameIt/#YouNameIt/I /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/List.14083
Sort...
Choose packages...
Choose DEPS...
Choose SUPPKG...
Create ZYPKG_INFO.tgz
TarHeader
Fetch /i-data/sysvol/admin/zy-pkgs/MetaRepository/NAS326/zypkg/5.21/ZYPKG_INFO.tgz - cat: write error: Broken pipe
failed
RELDIR=` dirname $0 `
CONFIG=/i-data/1e45b118/.PKG/MetaRepository/etc/MetaRepository.conf
. ${CONFIG}
FindApp()
case $1 in
curl)
[ ! -z "$CURL" ] && echo $CURL && return
wget)
[ ! -z "$WGET" ] && echo $WGET && return
md5sum)
[ ! -z "$MD5SUM" ] && echo $MD5SUM && return
esac
echo -n "FindApp $@ " >&2
unset app
for path in /bin/ /sbin/ /usr/bin/ /usr/sbin/ /usr/local/bin/ /usr/local/sbin/ /opt/bin/ /opt/sbin/ /ffp/bin/ /ffp/sbin/
do
[ -x ${path}$1 ] && echo found ${path}$1 >&2 && app=${path}$1 && break
done
[ -z $app ] && echo Failed! >&2 && exit 1
case $1 in
curl)
CURL=$app
wget)
WGET=$app
md5sum)
MD5SUM=$app
esac
echo $app
Fetch()
from=$1
to=$2
if [ "$NOCURL" != "true" ]
then
[ -z "$CURL" ] && CURL=` FindApp curl `
[ -z "$CURL" ] && NOCURL=true
fi
[ "$NOCURL" = "true" ] && [ -z "$WGET" ] && WGET=` FindApp wget `
echo -n "Fetch $@ " >&2
case ${from} in
local res=0
if [ "$NOCURL" != "true" ] ; then
local flags="-f"
[ "$to" = "-" ] && $CURL $flags $from 2>/dev/null || $CURL $flags $from 2>/dev/null >$to
res=$?
else
$WGET -t 3 -q $from -O $to
res=$?
fi
[ $res -eq 0 ] && echo succeeded >&2 && return $res
echo failed >&2
return $res
local res=0
local flags="-f --insecure"
res=$?
else
$WGET -t 3 -q $from -O $to --no-check-certificate # Yeah, I know this sucks
res=$?
fi
echo failed >&2
return $res
local res=0
local flags="-f"
res=$?
else
local pasv="--passive-ftp"
[ "$NOPASV" = "true" ] && pasv="" || echo -n "using PASV " >&2
$WGET -t 3 -q $pasv $from -O $to
res=$?
fi
echo failed >&2
return $res
esac
if [ "$to" = "-" ] ; then
[ -f $from ] && cat $from && echo succeeded >&2 && return 0
echo failed >&2
return 1
fi
[ -f $from ] && cp $from $to && echo succeeded >&2 && return 0
echo failed >&2
return 1
URLtoFilename()
echo $1 | sed 's|[/|:]|_|g'
StripLeadingAndTrailingSpaces()
[ -z "$1" ] && return
echo "$@"
RemoveComments()
echo "$@" | sed 's/#.*$//'
ReadConfig()
echo ReadConfig $@ >&2
local field=$1
local comments=0
[ "${field}" = "Comments" ] && comments=1 && field=$2
local myfield=0
while read line
do
line=` StripLeadingAndTrailingSpaces "$line" `
[ $comments -eq 0 ] && line=` RemoveComments "$line" `
[ "$line" = "" ] && continue
case "${line}" in
\[${field}]*)
echo -e "\tStart of block" >&2
myfield=1
continue
[ $myfield -eq 1 ] && echo -e "\tEnd of block" >&2 && return
esac
[ $myfield -eq 1 ] && echo "$line" && echo -e "\t$line" >&2
done <${CONFIG}
HtmlHeader()
echo Content-type: text/html
echo
TarHeader()
echo TarHeader >&2
cat >&1 <<__EOF__
HTTP/1.0 200 OK
Cache-Control: private
Server: bash/2.0
Connection: Close
Content-type: application/gzip
__EOF__
NotFound()
echo NotFound $1 >&2
cat >&1 <<__EOF__
HTTP/1.0 404 Not found
<html>
<head><title>404 Not Found</title></head>
<body>$1 Not Found</body>
</html>
__EOF__
ZYPKG_INFO_tgz()
exec 2>${SCRATCH}/ZYPKG_INFO.tgz.log
. ${RELDIR}/ZYPKG_INFO.sh
HandleZYPKG_INFO "$1"
local target="${SCRATCH}$1/ZYPKG_INFO.tgz"
[ ! -f "${target}" ] && NotFound && exit 0
TarHeader
Fetch "${target}" -
PKG_INFO_tgz()
exec 2>${SCRATCH}/PKG_INFO.tgz.log
HandlePKG_INFO "$1"
local target="${SCRATCH}$1/PKG_INFO.tgz"
TarHeader
Fetch "${target}" -
Index()
. ${RELDIR}/index.sh
Index_html
Main()
exec 2>/dev/null
echo "$0 $@" >&2
printenv >&2
echo "==========" >&2
[ -z REQUEST_URI ] && NotFound && exit 0
Index
InvokeEngine()
local path=` dirname $1 `
local file=` basename $1 `
[ "$file" = "ZYPKG_INFO.tgz" ] && ZYPKG_INFO_tgz "$path" && exit 0
[ "$file" = "PKG_INFO.tgz" ] && PKG_INFO_tgz "$path" && exit 0
local target="${SCRATCH}${1}"
exec 2>${SCRATCH}/zypkg.log
echo Request: $target >&2
[ ! -f "${target}" ] && NotFound ${target} && exit 0
local url=` cat ${target} `
dirname ${url} > /tmp/.MetaRepository/tmp/lasturl
TarHeader
Fetch ${url} -
exit 0
ParseInput()
[ -f /tmp/MetaRepository.log ] && exec 2>>/tmp/MetaRepository.log
local request=""
while read line
do
[ " " ">" "$line" ] && [ "$request" != "" ] && InvokeEngine $request
if echo $line | grep GET | grep HTTP >/dev/null
then
request=` echo $line | awk '{print $2}' `
# let's do *some* security
request=` echo $request | sed 's|/../|/|g' `
fi
done
cat >&1 <<__EOF__
HTTP/1.0 400 Bad request
__EOF__
exit 0
[ "$1" = "inetd-server" ] && ParseInput
[ -f /tmp/MetaRepository.log ] && echo "` date `: $0 $@ ${REQUEST_URI}" >>/tmp/MetaRepository.log
Main
drwxrwxrwx 2 nobody nobody 4096 Nov 23 14:02 Installed
-rw-rw-rw- 1 nobody nobody 33 Nov 23 13:59 Installed.520.md5
-rw-rw-rw- 1 nobody nobody 694 Nov 23 14:02 Installed.list
-rw-rw-rw- 1 nobody nobody 10 Nov 23 14:02 Installed.name
-rw-rw-rw- 1 nobody nobody 25 Nov 23 14:02 Installed.url
drwxrwxrwx 3 nobody nobody 4096 Nov 22 18:25 NAS326
-rw-rw-rw- 1 nobody nobody 2094 Nov 23 14:02 ZYPKG_INFO.tgz.log
-rw-rw-rw- 1 nobody nobody 47 Nov 23 12:26 _i-data_1e45b118_admin_zy-pkgs_MetaRepository_.url
-rw-rw-rw- 1 nobody nobody 29 Nov 22 18:30 _i-data_sysvol_admin_MyRepo_.url
-rw-rw-rw- 1 nobody nobody 45 Nov 23 14:02 _i-data_sysvol_admin_zy-pkgs_MetaRepository_.url
-rw-r--r-- 1 root root 15086 May 2 2020 favicon.ico
drwxrwxrwx 3 nobody nobody 4096 Nov 23 13:59 ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_
-rw-rw-rw- 1 nobody nobody 33 Nov 23 13:59 ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.520.md5
-rw-rw-rw- 1 nobody nobody 1354 Nov 23 13:59 ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.list
-rw-rw-rw- 1 nobody nobody 40 Nov 23 14:02 ftp___ftp2.zyxel.com_NAS326_zypkg_5.21_.url
drwxrwxrwx 3 nobody nobody 4096 Nov 23 13:59 http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_
-rw-rw-rw- 1 nobody nobody 0 Nov 23 14:02 http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.tmp
-rw-rw-rw- 1 nobody nobody 58 Nov 23 14:02 http___zyxel.diskstation.eu_Users_Mijzelf_zypkg-repo_fw5_.url
-rw-rw-rw- 1 nobody nobody 350 Nov 23 14:02 zypkg.log
That error looks mysterious, and don't see the cause directly. You reinstalled MetaRepository, but I can't remember if that will purge the database. You can delete the contents of \\<NAS>\admin\zy-pkgs\MetaRepository to reset the database, to see if that helps.BTW, zyxel.diskstation.eu is a bit flaky last months, you can exchange that with metarepository.tk, which is the 'actual' server, zyxel.diskstation.eu is only a CNAME forwarder.
Thank you very much Mijzelf. Will do and let you know
By the way, it seemms that the software list is updated correctly every now and then, roughly one time every four or five0 -
Yes, there is some cronjob in the firmware which checks for new packages regularly. Can't remember the interval, but that could be 4 hours.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
