Multi X WSQ50
cbm64
I have a three node multi. One is connected to the PPPoE, another is on an ethernet backhaul. The third is on the WiFi backhaul. I am having an issue with the third, after several factory resets, restarts and a full reset of the mesh it refuses to offer up internet either via ethernet or WiFi. The setup of the node goes fine, it reports a perfect positioning. Testing, reports a useful connection speed to the primary node. An ethernet test to the node shows as not connected both in the Multi app and on a computer. Is there anything else that can be done or is it likely to be faulty?
I should note, that it used to work!0
Hi @cbm64
Could you share what it the firmware on your Multy device and also the app version you're currently using?
Please send us the feedback on the Multy APP.
Thanks for coming back to me @Zyxel_Jerry sorry for the delay in coming back.Zyxel_Jerry said:Hi @cbm64
Multi: V2.20(ABKJ.8)C0
App: 2.5.4.221224
All multy's are reporting the same firmware. I have sent feedback as requested too.0 -
Can't say I am massively happy about the zip files in the feedback being password protected. I have no way of inspecting the data I have just shared. Can you confirm that no personally identifiable data has been collected?0
- 441 Beta Program
- 292 Service & License
