default profile in NWA5123-AC-HD
Hi @mat17,
You can edit the default SSID profile, replace the VLAN ID with the specific VLAN you expect to apply, then the default SSID will not use VLAN 1 to avoid the problem which you concerned.
Or you can add a new SSID profile configure with specific VLAN ID.
PATH: Local GUI >> Left sidebar “Configuration” >> Object “AP Profile” >> SSID >> +Add
After SSID VLAN ID configured, replace the default SSID profile with the new created one to the AP.
PATH: Local GUI >> Left sidebar “Configuration” >> Wireless “AP Management” >> MBSSID Settings (Radio 1 -> 2.4GHz, Radio 2 -> 5GHz)
Thank you.
Zyxel_HsinBo
Hi @mat17,
Thank you.
Zyxel_HsinBo
Thank you!
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 495 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 48 Wireless Ideas
- 286 Service & License
- 456 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
