NR5101 auto-boot after power outage?
hkrebs
servas,
i could not find information if the NR5101 is capable of automatic boot after a power outage?
i'm currently using a LTE4506 and this does not
ciao
H.
The design of the NR5101's power button is different from the LTE4506.
When you press the NR5101's power button, it will sink in. Only when you press it again will it bounce back.
So if the NR5101's power button is already pressed when the power outage happens, once the power supply restores, the NR5101 will boot again.
When the power button is pressed,
When the power button is pressed again or not pressed,
Regards,
Bob0
Regards,
Bob0 -
thanks for the answer, that's perfect for my needs ...0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
