default profile in NWA5123-AC-HD
mat17
mat17 Posts: 45 image  Freshman Member
edited May 2024 in Wireless
Hello support,
in my SSID list, I have a profile with name "default" which is for the administrative VLAN.
I can't remove it.
Is it something set up by the WLAN AP?
I don't want a SSID for my administrative VLAN, it's a security issue.
How can I remove it?
Kind regards
  • Zyxel_HsinBo
    Zyxel_HsinBo Posts: 513 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Administrator - WLAN Zyxel Certified Network Administrator - Switch
    edited December 2022 Answer ✓
    Hi @mat17,
    You can edit the default SSID profile, replace the VLAN ID with the specific VLAN you expect to apply, then the default SSID will not use VLAN 1 to avoid the problem which you concerned.
    Or you can add a new SSID profile configure with specific VLAN ID.
    PATH: Local GUI >> Left sidebar “Configuration” >> Object “AP Profile” >> SSID >> +Add
    After SSID VLAN ID configured, replace the default SSID profile with the new created one to the AP.
    PATH: Local GUI >> Left sidebar “Configuration” >> Wireless “AP Management” >> MBSSID Settings (Radio 1 -> 2.4GHz, Radio 2 -> 5GHz)
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • Zyxel_HsinBo
    Hi @mat17,
    Thank you.
    Zyxel_HsinBo
    Untitled Image
  • mat17
    Thank you!
