Help reviewing NCC log?
MeoM
MeoM Posts: 3 image  Freshman Member
edited April 2021 in Nebula
I recently got a new NWA1123-ACv2 and tried setting it up via Nebula cloud control - however, that didn't happen.
Can anyone help me go over the NCC logs to see if anyone messed with the AP while it was in its default (unprotected) state? Thanks!
Category Detail
system Port 0 is up! The link speed is 1000M/Full.
cloud-auth No response from NCAS over 15 seconds: NCAS disconnected
interface Interface lan has been changed.
wlan Wlan slot1 SSID 1 profile set.
wlan Wlan slot1 output-power 30dBm is set.
wlan Wlan slot1 Radio profile set.
wlan Wlan slot1 is enabled.
wlan Wlan slot1 WDS profile set.
wlan Wlan slot1 has been configured.
wlan Wlan slot2 SSID 1 profile set.
wlan Wlan slot2 output-power 30dBm is set.
wlan Wlan slot2 Radio profile set.
wlan Wlan slot2 is enabled.
wlan Wlan slot2 WDS profile set.
wlan Wlan slot2 has been configured.
force-auth Force User Authentication will be enabled due to http server is enabled.
system NTP update has succeeded. Current time is Thu Dec 17 01:27:24 GMT +00:00 2020.
system EnterpriseWLAN is configured successfully with startup configuration file.
zon ZDP: initial port 1 control block
system The AP has successfully booted.
smart-mesh Smart Mesh change state from BOOTUP to NAP.
system NTP update has succeeded. Current time is Thu Dec 17 01:28:40 GMT +00:00 2020.
cloud-auth NCAS connected: 204 Server is alive
system NTP update has succeeded. Current time is Thu Dec 17 01:32:11 GMT +00:00 2020.
system NTP update has succeeded. Current time is Thu Dec 17 01:33:26 GMT +00:00 2020.
wlan All radios are disabled due to country-code mismatch.
wlan Wlan slot1 country code changes from US to CA.
zon ZDP: initial port 1 control block [count=2]
file-manage WARNING: #configure terminal wlan slot1 exit, Country code do not match each other in the profiles you selected. Radios will be disabled to prevent RF violation.
wlan Wlan slot2 country code changes from US to CA.
wlan All radios are enabled due to country-code match.
user Admin's password has been changed.
wlan-dcs Radio1 configure DCS as SCHEDULE mode
wlan-dcs Radio2 configure DCS as SCHEDULE mode
system NTP update has succeeded. Current time is Thu Dec 17 02:16:29 GMT +00:00 2020.
system NTP update has succeeded. Current time is Thu Dec 17 02:18:07 GMT +00:00 2020.
pki Import PKCS#12 certificate "dot1x-cert.pem" into "My Certificate".
pki Prepare to import "dot1x-cert.pem" into "My Certificate"
smart-mesh Smart Mesh change state from NAP to ROOT.
wlan 5G Radio Tx stuck internal reset
smart-mesh Smart Mesh change state from ROOT to NAP.
  • MeoM
    Hi @MeoM
    Are you asking why the AP is always offline or cannot get the correct configuration from NCC?
    From the logs, the AP rebooted for three times, but I am not sure it was rebooted manually or by itself. However, the AP should connect to NCC successfully because it sent the logs back. If you still have the question, can you connect the AP back the environment and ensure it can access the internet? Also, please provide the org/site name and enable ZYXEL support for me(HELP > Support request). I will help to check the AP.
    Joslyn
    Hi Joslyn + greenlight,
    Thanks for the helpful suggestion @ contacting support via the app - I think I'll follow up from there instead. Thanks again!
  • MeoM
    Anyone?
  • Greenlight
    Greenlight Posts: 57 image  Ally Member
    You may use the "support request" function on Nebula Control Center to directly contact with Zyxel. They may check your settings and solve your problem.
    BTW, just saw the log time is at 12/17, so when you contact with Zyxel, you'd better tell them how's the AP's status after that time, so they can quickly understand your condition.
  • Zyxel_Joslyn
    Zyxel_Joslyn Posts: 360 image  Zyxel Employee
    25 Answers First Comment Friend Collector Fourth Anniversary
    Hi @MeoM
    Joslyn
  • MeoM
    Hi @MeoM
    Joslyn
  • Zyxel_Joslyn
    Hi @MeoM
    Can you share with us if the issue resolved?
    Thanks.
    Joslyn
  • 1123user
    1123user Posts: 6 image  Freshman Member
    Hi @MeoM
    has this been resolved? I am seeing my APs which has this message "zon ZDP: initial port 1 control block" having problem. not broadcasting wifi signal.
Nebula Tips & Tricks
