NR7101, on ship, want to connect Omni-directional antenna
benrofu
Hi
Can someone please share what connections inside nr7101 is for the lte antenna ?
I want to connect external antenna that works in every direction.
Hello @benrofu
The NR7101 has internal directional antennas:
"Better Signal, Work Wonders
Six 10 dBi long range directional antennas are built into the NR7101 to provide a focused networking coverage. Experience better, stronger signal strength and enhanced signal quality of 5G network for faster speed. Grab the NR7101, it’s efficient and can work wonders"
from https://www.zyxel.com/global/en/products/mobile-broadband/5g-nr-outdoor-router-nr7101
Looking at the NR7101 user guide available at https://support.zyxel.eu/hc/en-us/articles/4403365084818-5G-Devices-Advanced-Downloads-Firmwares-and-other-resources- shows that there is not any external antenna connectors.
So I think that you cannot do what you wish to do.
Merry Christmas.
Kind regards Tony
Yes, but i suppose someone can tell me wich connector for use of external antenna. I know the black lowest is for gps, but not sure the other ones.
I was planning to drill holes in cover and mount glands.
Hello @benrofu
At your own risk, you could use this information:
"Table 30: RM500Q-AE&RM502Q-AE Pin Definition of Antenna Interfaces
Pin Name I/O Description Comment
ANT0 AIO Antenna 0 interface: 5G NR: MHB_TRX & n41 TRX1 1) & n77/n78/n79_PRX MIMO; LTE: MHB_TRX & UHB_PRX MIMO 2) WCDMA: MHB_TRX 1400–5000 MHz
ANT1 AIO Antenna 1 interface: 5G NR: LB_TRX & MHB_DRX MIMO & n41_DRX1 1) & n77/n78/n79_DRx MIMO LTE: LB_TRX & MHB_DRX MIMO & UHB_DRX MIMO 2) & LAA PRX WCDMA: LB_TRX 600–6000 MHz
ANT2 AIO Antenna 2 interface: 5G NR: LB_DRX & MHB_PRX MIMO & n41 TRX0 1) & n77/n78/n79_TRX LTE: LB_DRX & MHB_PRX MIMO & UHB_TRX 2) WCDMA: LB_DRX 600–5000 MHz
ANT3_ GNSSL1 AI Antenna 3 interface: 5G NR: MHB_DRX MIMO & n41 DRX0 1) & n77/n78/n79_DRX LTE: MHB_DRX & UHB_DRX 2) & LAA DRX WCDMA: MHB_DRX GNSS: L1 1400–6000 MHz
Notes
1. 1) NR TRX1 = TX MIMO + PRX MIMO; NR DRX1 = DRX MIMO. 2. 2) UHB frequency range: 3400–3800 MHz
And
Table 31: RM500Q-AE & RM502Q-AE Antenna MappingAntenna WCDMA LTE 5G NR LB (MHz) MHB (MHz) n77/n78 (MHz) n79 (MHz) Refarmed n41 n77/n78/ n79
ANT0 MHB_TRX MHB_TRX, UHB_PRX 1) MIMO MHB_TRX, UHB_PRX 1) MIMO TRX1 2) PRX MIMO - 1452–2690 3300–4200 4400–5000
ANT1 LB_TRX LB_TRX, MHB_DRX MIMO, UHB_PRX 1) MIMO, LAA PRX LB_TRX, MHB_DRX MIMO, UHB_DRX 1) MIMO, DRX1 2) DRX MIMO 617–960 1452–2690 3300–4200 4400–6000
ANT2 LB_DRX LB_DRX, MHB_PRX MIMO, UHB_TRX 1) LB_DRX, MHB_PRX MIMO, UHB_TRX 1) TRX0 2) TRX 617–960 1452–2690 3300–4200 4400–5000
ANT3_ GNSSL1 MHB_DRX MHB_DRX, UHB_DRX 1), LAA_DRX MHB_DRX, UHB_DRX 1), DRX0 2) DRX - 1452–2690 3300–4200 4400–6000
Notes1. 1) UHB frequency range: 3400–3800 MHz. 2. 2) NR TRX1 = TX MIMO + PRX MIMO; NR DRX1 = DRX MIMO. "
from https://www.quectel.com/wp-content/uploads/2021/04/Quectel_RM500Q-AERM502Q-AE_Hardware_Design_V1.0.pdf
The antenna numbering on the Zyxel board might not be the same.
Again, use this information at your own risk.
No guarantees from me as a user, and I don't work for Zyxel.
Merry Christmas.
Kind regards Tony0 -
Thanks, i will check out!1
And maybe
"Table 32: RM500Q-AE&RM502Q-AE Operating Frequencies"
At your own risk.
Merry Christmas.
Kind regards Tony
Hmm.... Not sure if i got any wiser...
Hello @benrofu
The datasheet for the RG502QAEAA-M20-SGASA module says that it has 9 antenna connections.
蜂窝天线: 6 + 2 (n79), GNSS: × 1
Datasheet linked from https://www.mouser.co.uk/ProductDetail/Quectel/RM502QAEAA-M20-SGASA?qs=iLbezkQI%2Bsi9ukHixHgcsg==
At your own risk.
Merry Christmas.
Kind regards Tony0
- 435 Beta Program
- 176 Nebula Ideas
- 426 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
